Hello all's,
first sorry for the not so good english, this is not my mother langage.
I like to ask you help, i developping a command pump circuitry with microchip pic. This is a pwm command to slow down-up the speed of the pump and also reverse the fill-up and fill-down the fuel.
My problem is that sometime the relay is not activated when i reverse the rotation of the pump. I don't no if the relay is 'glued on' while current is passing, or if this is an effect of the dc-motor. The result is that the pump always run in the same direction. If no motor is attached, the reverse seams to run well !
I attach the part of the schema that are in use. If you have some idea, thanks' for help.
Fabrice
Fabrice
