ISR for timer1 in cc2430
Discussion in 'Embedded Systems and Microcontrollers' started by hazzman, Jan 22, 2008.
  1. hazzman
    Dec 17, 2007
    13
    Hi people,
    Started doing interrupt programming for my cc2430 project, and i think i've done all the config stuff with the timer1 like shown below and in my ioCC2430.h file the following interrupt vector is associated with Timer1:
    Code ( (Unknown Language)):
    1.
    2. #define  T1_VECTOR  VECT(9,0x4B )   /*  Timer 1 (16-bit)Capt./Compare/Overfl */
    3.
    so my main code is like:
    1.
    2. void main()
    3. {
    4.   T1CTL = 0x0E;   /*  tick_freq/128 -> 32M/128, modulo: 0x0000-> T1CC0*/
    5.   T1CCTL0 = 0x44; /*  set output on compare, compare mode, no capture */
    6.   T1CC0H = 0xEA;
    7.   T1CC0L = 0x60;    /* compare 60,000 for example */
    8.
    9. OVFIM =1; /* Timer 1 Overflow Interrupt Mask   */
    10. T1IE = 1; /* Timer 1 Interrupt Enable  */
    11. }
    12.
    SO WHAT'S THE INTERRUPT SERVICE ROUTINE when the interrupt occurs?
    I couldn't find it anywhere!
    p.s. i'm using IAR Workbench
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    You have to write your own ISR.
  3. hazzman
    Dec 17, 2007
    13
    sorry slight mis-understanding here....
    I know i have to write my own ISR here for timer1, what i meant was:
    What format does the ISR have to be?
    e.g. I have seen this somewhere...
    1.
    2. void timer1_isr(void) interrupt #no.
    3. {
    4.
    5. }
    6.
    I've tried this format and it doesn't seem to work.
    What i also meant from the post is that i could not deduce what format the ISR function format had to be from the given header file (io2430.h) for IAR Workbench.
  4. nanovate
    May 7, 2007
    665
    This is a compiler specific question:
    IAR uses something like this I believe --> __interrupt void Timer1_ISR (void)
    Double check their documentation though....
