I know if you use isolation transformers to work on stuff your less likely to get shocked (at least in theory).
I'm curious though about a few things. I have an old isolated power conditioner made by RTE Deltec, and an old TV ISO tap. I tested the TV ISO tap if I put a meter on the output and the other meter lead on chassis, or ground pin hole in receptacle on other side i'd get like 50V on the neutral and like 150 on the hot to gnd. The power conditioner is not registering on neutral, but hot acts similar.
I did the test with both digital and analog meters. Analog showed less voltage in most the cases except measuring output neutral to hot. So it seems it is isolated, and voltage is there, but thinking its low amperage.
I plan to use the conditioner as a way to isolate and protect my bench power strip. I opened it to see what shape it was in, and noticed the neutral and GND are bonded. I'm thinking that for what I want to do I should remove that bonding.
