Isolation transformer
Discussion in 'General Electronics Chat' started by takeitapart, Sep 14, 2013.
  1. takeitapart
    Jun 20, 2010
    21
    I am working on a number of projects that need 90volts DC. Many of you have suggested an isolation transformer along with my bridge rectifier. I am having a hard time finding an isolation transformer (ie inexpensive). Any suggestions for 90 volt DC power 1-3 amp? low cost?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Depends on what you need to power at 90VDC @ 3A.
    You don't need an isolation transformer. What you need is a 90VDC @ 3A power supply.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    For a transformer you will need a 60-65VAC secondary for 90vdc.
    90 x .707.
    Max.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If you need cheap solution. A switch mode power supply will probably be the thing.
  5. PackratKing
    Jul 13, 2008
    850
    216
    OK>>> Anybody ... rank amateur here... Aren't all trans. basically isolation units, or are we speaking only of a 1:1 winding that gets you one step off the mains... ???
  6. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    A 1:1 would give you 170VDC.
    Some transformers are auto transformers, so do not isolate.
    Such items as Variac's do not either.
    Max.
    PackratKing likes this.
