Isolation Transformer Question
AnalogKid
Joined Aug 1, 2013
11,056
That is called a balun. Differential signals enter on 1 and 2 and exit on 3 and 4. The coupled inductors act as a common mode choke, exhibiting high inductance (and impedance) to common mode signals while have relatively little effect on the differential signals. This is a common technique to filter radiated noise from RF and other high frequency signals.
ak
Ramussons
Joined May 3, 2013
1,414
ak
The explanation of working is fine, but the term "Balun" is not. It is a Series Filter.
"Balun" is a short form of the "Balanced" to "Unbalanced" transformer used to interface Balanced Transmission Lines to Unbalanced. Like a 75 Ohm Coax feeder to a 300 Ohm Antenna.
AnalogKid
Joined Aug 1, 2013
11,056
Yup. My bad. A while ago I combined the two in three straight projects, and they got compounded in my little brain.
ak
