I am planning to tap a telephone line through an isolation transformer 600O/600O of 1:1 type. In our local market it is not readily avail. After a lot of search I have found one Dax 56K DX-56PU modem from one electronic shop and they put forward $45 for modem. Actually I only want one small transformer inside it.
Find the attachment. Non-SMD Type transformer with white colored core. T1 AASUPREME.
I have heard there also exists modem line transformers with 600O primary and different secondary (600,330,560,etc) resistances. How can I fix this should be 600O/600O Type.
Does it is mandatory to use 600O/600O in Telephone tap......
Can I possible to take outs from transformer leads on underside of the PCB without desoldering the costly PCB board.
