ISOLATION FOR SIGNAL AMPLIFIER
Discussion in 'General Electronics Chat' started by viju, May 1, 2009.
  1. viju
    Thread Starter Senior Member
    Sep 28, 2008
    120
    How to isolate the signal amplifier i.e from the sensor to the measuring circuit? I found in the internet ISO 122, ISO 124 solve this purpose.
    How to connect this isolation amplifier? Do I need to connect at the amplifier input or at the output of amplifier?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I have used the ISO 122 - works fine.
    The only problem is that you need two power supplies - one isolated.
    I used a small isolated (1W) DC-DC dual output (+/- 15V) converter module for the isolated side DC supply. They aren't cheap!
  4. viju
    Sep 28, 2008
    120
    I have decided to use two power supplies.But how to interface? I have decided to use this IC for gain amplifier ( 1:100). Should I have to feed signal into the IC or output of the amplifier to be connected to the IC?
    Pls guide.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    The ISO122 has unity gain so if you require 100x gain you need to decide on which side of the isolation barrier you want to do the amplification.
    If you have a very low input signal which is subject to noise &/or sitting at an unusual common mode level, you might consider running a differential input stage with the 100x gain before going to isolation. You can use your isolated power source to run this as well.
    See this link for a typical diff amp.
    http://focus.ti.com/lit/ds/symlink/ina111.pdf
    You can buy complete single power supply isolation modules with gain but they can get quite expensive.
  6. viju
    Sep 28, 2008
    120
    Thankyou very much for the information T N K.I have built the application and it's working fine.
