Isolating Transformer
donaldm444
Joined Jul 16, 2010
23
I have an isolated transformer I am mounting on a PCB, with isolated transformers do you know if it is okay to connect the negative input terminal to the negative output terminal (e.g. so they share a common ground)?
Thanks,
Don
34,408
You can but then it's no longer isolated. :rolleyes:
DickCappels
Joined Aug 21, 2008
10,169
Don, Please describe what you mean by isolation transformer. I'm beginning to think that there is more than one definition of isolation transformer at work here.
donaldm444
Joined Jul 16, 2010
23
The input and output of the transformer is isolated from each other. The model is TDK Lambda PXE3024S12.
donaldm444
Joined Jul 16, 2010
23
