Isolating high-speed connectors
Discussion in 'General Electronics Chat' started by Dalaran, May 25, 2010.
  1. Dalaran
    Thread Starter Active Member
    Dec 3, 2009
    168
    What would be the best way to isolate 2 high-speed connectors which will be close-by on the same PCB. There will be a Gig-E next to a BNC which will feed SD video.
    Any and all help is appreciated. I am new to the world of PCB's but not electronics :).
    Thanks.
  2. Dalaran
    Dec 3, 2009
    168
    Is there any general recommendations then for isolation of any 2 or more high speed connectors placed closely together on a PCB? Or should I just expect to have no problems with interference of the signals. The PCB has active signal traces on the top and bottom and inner power and ground planes.
    Cheers.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Sorry that your inquiry has not generated any replies up to this point.
    This forum is oriented towards beginners. Your topic is more advanced.
    Have a look at this page:
    http://www.smps.us/pcb-design.html
    If you think that placing a pair of high frequency signals next to each other will have no consequence, you will have a rather rude awakening.
