I have a two-pole conductivity probe which operates on the principle of measuring the resistance of the liquid. Basically I use a 555 timer to generate an osillation and pass that current through the two poles of the conductivity probe. I then measure the frequency of the osillation and calculate the conductivity with a simple equation.
My problem is that the two pole probe is greatly effected by stray current and and a ground probe in the tank. Also, the conductivity probe effects the accuracy of a pH probe in the same tank.
Can anyone suggest how to isolate the conductivity probe from external effects? Shielding, etc...
