Isolate uart of two MCu
aamirali
Joined Feb 2, 2012
412
I have to isloate uart of two MCU with the help of optocoupler.
I have made a circuit which I had attached.
is it the correct way to do?
For me its looks ok.
ericgibbs
Joined Jan 29, 2010
18,872
The signal polarity looks OK.
The 1K's are too high in value, I would suggest 270R or 330R in order to get a fast/hard switch On of the Emitter LED's.
E
Shagas
Joined May 13, 2013
804
Looks good. What baud rate are you planning on using ? If it's high then I suggest you check out the datasheet of the optocoupler to make sure that it has fast enough rise/fall times because last optocoupler that I worked with was pretty slow. This could (potentially) be a problem to you but most likely not.
