Isolate DC
Discussion in 'The Projects Forum' started by rene.qvist, Aug 4, 2013.
  1. rene.qvist
    Aug 1, 2013
    5
    Is it possible to split one dc power source into 2 isolated power sources?
    Reason im asking is because I have a sound system that requires 18+ and 18- @ 1A and instead of using 2 regular power supplies to do this, i was wondering if it was possible to split a single source into 2 isolated ones...
    Thanks in advance
  2. MrChips
    Oct 2, 2009
    12,642
    3,456
    They do not need to be isolated.
    Yes, you can create a split DC power supply from a single DC supply.
    What is the voltage and current rating of your DC supply?
  3. rene.qvist
    Aug 1, 2013
    5
    The current is 18 V 1A from the powersupply
    My sound system needs
    0v
    18V
    0v
    -18V
  4. crutschow
    Mar 14, 2008
    13,505
    3,378
    Splitting the supply into ±18V will half the current so you will only have 0.5A available for each voltage. You need another 1A power supply.
  5. rene.qvist
    Aug 1, 2013
    5
    My mistake in Info, I do have a 2 amp I want to split into two
  6. MrChips
    Oct 2, 2009
    12,642
    3,456
    Good. Then you need a 18VDC to -18VDC converter.
    LM78S40 is shows one example of how to do this.
  7. MrChips
    Oct 2, 2009
    12,642
    3,456
