Iso 124
Discussion in 'General Electronics Chat' started by AFAS87, Apr 25, 2010.
  1. AFAS87
    Oct 9, 2008
    23
    hi,,,
    i wanna ask about the ISO124 isolation amplifier
    can i use it to measure 100 VD using μC...
    i wanna use avoltage divider then ISO124
    any one has an idea about it circuit and how it is used.
    thanks
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Did you read the datasheet?
    The input range is about ± 10 volts.
    The input impedance is about 200 K Ohms.
    You need to make an voltage divider of 1 : 10 that has low output inpedance.
    Bertus
  3. AFAS87
    Oct 9, 2008
    23
    thank you for your answer.... but ± 10 at minimum.
