ISD1110 "SP+" goes to LM386N-3 "IN-" ? Is this right?
Discussion in 'General Electronics Chat' started by xnihilo, Jan 6, 2009.
  1. xnihilo
    Thread Starter Active Member
    Nov 20, 2008
    33
    Hello.
    When using a differential input in LM386N-3 from an output from ISD1110P, it seems that the SP- goes to lm386 IN+ and, the SP+ goes to the IN-.
    This is found in the ISD1110P datasheet, is there an error or is this correct, and why?
    Thanks for any comments.
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    please post the datasheet
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The speaker outputs of the voice recorder IC ISD1110 have a DC voltage.
    The inputs of the LM386 amplifier must be at 0VDC and have a resistor to 0V inside.
    So use a 0.1uF coupling capacitor from each speaker output of the voice recorder IC to each input of the LM386 amplifier.
  4. xnihilo
    Nov 20, 2008
    33
    In fact this relates to LM386 datasheet, ISD1110P datasheet and some WINBOND Application notes.
    This configuration is when you connect differentialy the ISD1110P SP+ and SP- to LM386 IN+ and IN-.
