ISCET associate ?
Discussion in 'General Electronics Chat' started by RFrog, Jul 16, 2008.
  1. RFrog
    Jul 16, 2008
    I recently took (and passed) the associate ISCET exam. There is one question that still bothers me. It is:
    If a TTL output is providing 0V, what is this called?:
    A: Current sourcing
    B: Current sinking
    c: Asserted
    D: Unasserted
    It seems to me that both B and D are correct. Is this so? What would be the best answer?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    It's B: current sinking.
  3. nomurphy
    Aug 8, 2005
    567
    12
    Yes, it's B. Neither C or D is correct.
    A signal may be asserted (or deasserted) either high or low depending upon the operation required in the design.
    For instance, a xstr that enables a relay by sinking current would be a low assertion at the relay coil terminal (other terminal would be at voltage), and would typically use a NOT indicator in the signal/net name; such as ~RELAYEN, RELAYEN*, /RELAYEN, or have an overbar (you could also call it RELAYOFF without the negation, but to the same effect -- in this case high, or open, would mean off).
  4. RFrog
    Jul 16, 2008
    Excellent! That was my answer.
    Thanks!
