Is this wrong?
Discussion in 'Off-Topic' started by Brownout, Apr 9, 2013.
  1. Brownout
    Jan 10, 2012
    2,375
    998
    Is it wrong for me to get really jazzed when something of mine works, even if it's something really simple? 20 years doing this, and I still haven't lost the thrill.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    It depends.
    If it is a simple project and takes little time to complete, then I celebrate.
    If it is a very complex project and takes months to complete, then I celebrate.
    If it is a simple project and takes months to complete, then I curse.
    If it is a very complex projct and take little time to complete, ...just joking, there's no such thing.
    DerStrom8 likes this.
  3. gerty
    Aug 30, 2007
    1,154
    304
    What do you think the "Happy Dance" was created for :D:D
  4. spinnaker
    Oct 29, 2009
    5,102
    1,190
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep, it's wrong.
    Actually it would be more wrong if you didn't. It would mean you are in the wrong profession.
  6. #12
    Nov 30, 2010
    16,705
    7,355
  7. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Wrong no. Pathetic yes. :) But I am pathetic too. You should have seen how excited I got when a program I wrote successfully enumerated an USB GPS device attached to my Android tablet PC. Now for the hard part and get it to communicate.
    I need to get a life. :) Oh well I guess it is better than having a hobby of drinking to excess like my neighbor does. Nothing wrong with a drink or two now and then but when it becomes a way of life you have issues. :).
  8. Markd77
    Sep 7, 2009
    2,803
    594
    It's pretty normal for me. I got unexplainably happy when I saw how good this etch was now that I've splashed out on a laser printer. Still using the UV method and if anyone has seen the fairly mediocre boards I was making this is a massive improvement (although I messed up the alignment of the reverse side). The five large pads are on a 2.54mm pitch and the chip has a 0.64mm pitch.
  9. tubeguy
    Nov 3, 2012
    1,157
    197
    I've been building and repairing electronic stuff since Disney World opened in Florida.
    A month or so ago I worked on a buzzing Kalamazoo Model Two amp for a harp player and was quite excited when I powered it up after a re-cap, plugged in a Strat, and it sounded great.
    Just never gets old for me :cool:.
  10. loosewire
    Apr 25, 2008
    1,584
    435
    Mark77 ,explain...do you print layers ,then etch...I keep hearing about 3-D printers
    and all the good stuff you can make. Are you in to that also or just etching copper
    curcuits.
  11. maxpower097
    Feb 20, 2009
    795
    388
    Not at all. I feel the same way every morn I wake up still breathing. Seriously though no, its always good to have something work the way it should, whether it be 4G mesh network, or a cabinet from IKEA.
  12. Markd77
    Sep 7, 2009
    2,803
    594
    I just print the design on clear plastic, expose the presensitised board to UV light through the print, develop (which dissolves the board coating where it has been exposed), then etch away the unprotected copper.
    3D printing is out of my price range at the moment.
  13. Brownout
    Jan 10, 2012
    2,375
    998
    Design seems to be running in 16 month cycles. 2-3 months to design, then 13-16 months to test, integrate, program, more testing and then planning and researching the next project. Result is it's been well over a year since I last designed. Wonderful to be back!
    The project is a simple register file accessble over PCIe. Just the first part of a much larger design project.
    Some of you worked with me on a couple issues I was having integrating PCIe. Thanks to those who did!
  14. Brownout
    Jan 10, 2012
    2,375
    998
    Engieering is life. It's what makes modern life possible.
