Is this thyristor module considered bad ?
LETITROLL
Joined Oct 9, 2013
218
I have found continuity between the cathode and gate of this high power thyristor module , is this a sign of bad component ??
or is it something normal for this type of SCRs
MaxHeadRoom
Joined Jul 18, 2013
28,700
If it is zero ohms in both direction, then this indicates most likely shorted, there is normally a difference in resistance depending on polarity of the meter, there is direct continuity between the centre screw and the trigger terminal 5 as seen on the diagram.
Are you testing on the resistance scale or diode check?
Max.
LETITROLL
Joined Oct 9, 2013
218
Max.
I have just took a test with diode mode , and it displays 000 + beeping .
i didn't check with ohmeter . i will and see what this is giving
