Is this the RMS value?
Papabravo
Joined Feb 24, 2006
21,228
No, it is the peak value, which occurs when the value inside the parentheses is equal to 90 or pi/2 radians. This makes the value of the sin function equal to 1.
If I didn't know better I'd almost suspect you of trolling.:D
WBahn
Joined Mar 31, 2012
30,083
I would recommend that you go back to the definition of what rms voltage is (not some formula for it, but what it means, namely that the rms value of a waveform is equal to the voltage that a DC source would have that dissipated the same amount of average power in a purely resistive load). From that, you should be able to come up with the formula that thumb2 gives and, in the process, cement in your knowledge what rms voltage is and why rms stands for what it does.
