Is this superposition example wrong?
Discussion in 'General Electronics Chat' started by hunterage2000, May 2, 2010.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
  2. Ghar
    Mar 8, 2010
    655
    73
    The higher resistance will always have less current than the lower resistance when in parallel.
    In this case you have R1 = 4 ohms and R2 = 2 ohms.
    Since they're in parallel in that 7 V circuit, R2 must have twice as much current as R1.
    R3 will get the sum of those two currents.
    In the 28 V circuit R2 and R3 are in parallel, and R3 is 1 ohm. Therefore the situation is swapped, with R3 having twice the current of R2.
    R1 will get the sum of those two currents.
  3. hunterage2000
    May 2, 2010
    402
    I used for I1 2/2+4 x 3 = 1 and I2 4/2+4 x 3 = 2, cant see where im going wrong
  4. Ghar
    Mar 8, 2010
    655
    73
    You really need to use brackets.
    I1 = 2/(2+4) * 3 = 1
    So I'm not sure what the issue is. I1 is the current through R1, yes?
    Then it agrees... 4 ohm R1 gets 1 A, 2 ohm R2 gets 2 A.
    Where's the disagreement?
  5. hunterage2000
    May 2, 2010
    402
    Just I thought as R1 = 4 R2 is 2 then I1 would be I1 = 4/(2+4) * 3 = 2 not 1 which it says in the tutorial. Is this the correct way of doing this because the 28v circuit was correct.
  6. Ghar
    Mar 8, 2010
    655
    73
    With current division the numerator is the resistance in the other branch.
    So:
    I1 = Itotal * R2 / (R1 + R2)
    I2 = Itotal * R1 / (R1 + R2)
    The 28V circuit can do the same thing:
    Itotal = 6 A.
    R2 = 2 ohms
    R3 = 1 ohm
    I2 = 6 * 1 / (2 + 1) = 2 A
    I3 = 6 * 2 / (2 + 1) = 4 A
  7. hunterage2000
    May 2, 2010
    402
    cheers mate thanks for clearing that up :)
  8. Ghar
    Mar 8, 2010
    655
    73
    You're welcome.
