This is a crossover for the "Taurus" project. These are intended to be mid-end and relatively cheap speakers. However it is my wish to submit it here too for a final revision. My questions are?
Are the values OK?
Is the phase shift of 180º between the woofer and the tweeter correctly assumed (note the tweeter "polarity" reversal when compared to the woofer)?
C1/3 – Capacitor Visaton ELKO spez. 3,3µF;
C2 – Capacitor Visaton ELKO spez. 15µF;
C4 – Capacitor Visaton ELKO spez. 6.8µF;
FTE1 – Tweeter Visaton SC 10 N 8 OHM;
FTE2 – Woofer Visaton SC 13 8 OHM;
J – RCA plug;
L1-3 – Coil Visaton SP 0,47mH 0,6mm;
R1 – 6,8Ω carbon resistor (5% tol., 1W);
R2 – 10Ω carbon resistor (5% tol., 2W).
You can see the schematic diagram in the attached PDF file.
I really need a third opinion on this. Thanks in advance.
Are the values OK?
J – RCA plug;
