Is this resistor any good?
Discussion in 'General Electronics Chat' started by stanman11, Feb 17, 2012.
  1. stanman11
    Nov 23, 2010
    230
  2. stanman11
    Nov 23, 2010
    230
    15v
    9128
    4t110
    k107
    thats all the numbers on it but i cant find crap on them
  3. ErnieM
    Apr 24, 2011
    7,447
    1,628
    Nothing looks fried to me.
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The metal case device is a 1960's or early 1970's axial tantalum capacitor, whcih has blown and blew/melted out the epoxy end. They were sometimes called a "MILspec cap" as many had a MIL label. I have a heap in my old tantalums box.
    Check it's number but it is likely in the 10uF to 100uF range (but is smallish so closer to 10uF), and was also likely to have been exposed to excessive voltage (so check all the voltage regulation parts).
    Sometimes you get diodes in that package but I'm pretty sure it's a tantalum as it has the 15v label. There should also be a + sign on the open end. Unsolder it and check if the uF number is on the bottom?
    Otherwise it could be k107 as in 10uF with a k tolerance.
  5. atferrari
    Jan 6, 2004
    2,674
    785
    Isn't a "22" what you can read?
    Taking digital pictures today is quite cheap. Could you try two or three more?
