Is this Relay setup possible ?
Discussion in 'General Electronics Chat' started by swifty, Aug 15, 2006.
  1. swifty
    Aug 15, 2006
    Hi all,
    I would like to do the follow - which seems easy in principle, but I am stuck on one part:-
    I'd like to have a relay close when 12v is applied but then to open again after approx 2-3 secs, and stay open even with the 12v still applied - I'd like to reset the relay to allow it to close again only when the 12v supply has been lost.
    I have been reading up on delay relays but from what I understand these would either
    a) keep opening and closing the relay (with the time delay) while the supply is active.
    b) close the relay and then only open again once supply is lost + time delay
    Have I understood this correctly ?
    Is it even possible to get the desired setup ?
    If it makes things clearer - Its to activate a digital switch to turn something on when another device powers up. Hence if the digital switch is held closed for more than about 3 secs the device will turn back off.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    Try a capacitor in series with the relay coil. Your reset switch would discharge the capacitor.
  3. swifty
    Aug 15, 2006
    Thanks for your suggestion, would you mind explaining how that would work ?
    I'm confused as to how this would solve the problem of just activating the relay once for a few seconds, then opening the relay until power is cut and re-applied...
    Unless I'm missing something - or have misunderstood you, would that setup not just keep the relay closed when power was cut - until the capactior had discharged ?
  4. nomurphy
    Aug 8, 2005
    You are describing a one-shot circuit. If you search applications for 555 and 556 timer circuits you should find what you need.
  5. Chris Wright
    Jul 26, 2006
    How are you coming with your project? It looked like a good exercise for a neophyte like myself, so I've been playing around with it and this is what I've come up with based on a 555 timer. The time delay is set by the relation of R1 and C1; something like: Time (sec) = R1 in ohms times C1 in Farads ( It might be 1.1xR1xC1, someone will set us straight). But a resistor R2 is needed to bleed off C1 to reset C1 after the power is removed, so you just have to play with it. Here's how, go to
    and download the applet zip file. It's a slick little animated circuit simulator with a graphical interface that you just draw your circuit and watch it work (or not??). A link to the directions is on this page also.
  6. richbrune
    Oct 28, 2005
    I think the function you require is called "ON DELAY". You must select an "ON DELAY" function time delay relay with the option for "NORMALLY CLOSED" and "NORMALLY OPEN". Connect the load you want to run to the "NORMALLY CLOSED" connectors. When power is applied to the time delay relay, the contacts do not transfer until the specified timing cycle is complete, at which time the relay contacts open. When power is disconnected from the time delay relay the relay contacts will be in the "NORMAL" condition, which is closed. Omron makes one, I've got them through WW Grainger---Rich
  7. gopi_electron
    Feb 1, 2008
    thank you , it was very useful since i dont know whats ON delay before this but, whats WW Grainger---Rich, wheres it,how do i get that
