Heres a better resolution circuitry sketch. I will try to use the same supplies from the rectifying link posted earlier. Please critique!
Yes, I need help sir!Your sketch seems to indicate that the output of your shaker uses a 120VAC type receptacle, which has a wallwart charger plugged into it. The output of the wallwart is connected to a battery pack. Did I miss anything or is that what your intent is? If so, we have a lot to talk about!!
How in the world did we go from charging a battery directly from your shaker (DC OUTPUT) ... to this scheme? For this scheme to work your shaker would have to produce 120VAC @ 60Hz! This is not what this discussion has been about,... and we're past 43 posts!Yes, I need help sir!
I am attempting to charge a battery pack from the shaker. I was not completely confident in charging the battery pack by ridding myself of the battery packs adaptor. If I cut off the packs adaptor, and attach the battery pack to the positive and negative of the circuitry, will it work then?How in the world did we go from charging a battery directly from your shaker (DC OUTPUT) ... to this scheme? For this scheme to work your shaker would have to produce 120VAC @ 60Hz! This is not what this discussion has been about,... and we're past 43 posts!
I have a idea of what you are saying. But could you be a bit clearer?It will be much easier to mimick the original charger than creating 120Vac.
kubeek is saying the same thing that I told you in post 47.I have a idea of what you are saying. But could you be a bit clearer?
I know that. I'm doing a shaker to because its different than your normal manual generator.kubeek is saying the same thing that I told you in post 47.
You would have been so, so....so far ahead if you had simply bought a small permanent magnet motor, added some pulleys or gearing and a hand crank. This all could have been mounted to a wood base. With a gear-head motor (none worm gear type) you could connect the crank directly.
http://www.mpja.com/prodinfo.asp?number=16815+MD
This concept would have been a thousand times more practical and efficient than a shaker.
I did. In fact, between kubeek and myself we've told you multiple times. Are you reading the replies?I know that. I'm doing a shaker to because its different than your normal manual generator.
So can you tell me were I'm going wrong in using a shaker generator to trickle charge a rechargeable battery pack?
What the hell are they teaching in college level electronics these days? We seem to have nothing but "Greenies" teaching (pie in the sky) alternative energy. It's beginning to make me ill! In the old days the EE student had two years of intensive electronics and physics math before they ever saw a real resistor!I'm currently working on a Summer project for my degree (I'm just two semesters in).
I apologize for upsetting you guys. I'm doing core work now (freshman). I haven't taken any classes pertaining to electronics yet. I'm just trying to do a project. I talked to my professor about doing the project, he was some what interested. I do not like to talk to people about doing things and then not doing what I stated I was attempting to do. This is not a life or death situation.The most depressing thing about this topic is stated in the first post.
Thanks man! I plan on learning as much as possible from this forum before its time to take my major classes.Attach rectifier of the shake charger directly to the battery.
Is that plain enough?
by Duane Benson
by Duane Benson
by Jake Hertz
by Jake Hertz
