Is This Possible.
Discussion in 'The Projects Forum' started by MrMaxwell, May 28, 2011.
  1. MrMaxwell
    May 28, 2011
    26
    I'm currently working on a Summer project for my degree (I'm just two semesters in). I only have 10 days to decide all of which parts needs to be ordered. The money that will be used to purchase the parts is not mine -- it is my professors. So I really don't want to "F" up -- get it?
    The question: What would be the best way to convert short lived 1/4v to 6v AC currents, so that they can be stored on a commercial rechargeable battery pack?
    http://www.harborfreight.com/person...pack-67728.html
    I'm attempting to store the small AC currents made from a simple shake-generator (http://www.creative-science.org.uk/gensimple1.html) onto the device above, or onto something similar.
    I've been looking into converters, rectifiers, and other smiler devices, but I'm still a bit confused. Google has helped me to generate a bit of understanding of what I'm looking for. The 100v-110v input minimum that I suspect the magnum-rechargeable-pack's wall adapter to have is the key factor for my lack of confidence for the part ordering.
    Can anyone help me?
  2. #12
    Nov 30, 2010
    16,665
    7,310
    Your first link didn't work for me...404 Page not found.
    Anyway, a low voltage rectifier seems to be needed. They are called Shottky. AC must be rectified to put it into a battery, and tiny little volts have trouble getting through rectifiers, but the Shottky diodes have low voltage requirements at low currents.
  3. MrMaxwell
    May 28, 2011
    26
    http://www.harborfreight.com/personal-electronics-portable-charging-pack-67728.html
    I'm trying to store power/charge this rechargeable pack with small, short lasting AC currents from a shake-generator.
    Are you saying that I basically need to place the Shottky before the female power plugin adaptor, then plug the rechargeable packs adapter into the female power adaptor, and problem solved?
  4. MrMaxwell
    May 28, 2011
    26
    I've been looking at this rectifier.
    http://www.virtualvillage.com/Items/007901-023
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Get one of the shaker powered flashlights and do an autopsy on it. In technical circles that is called "reverse engineering"!
  6. ErnieM
    Apr 24, 2011
    7,435
    1,625
  7. MrMaxwell
    May 28, 2011
    26
    I'm trying to use the shake light to charge a rechargeable battery pack. The battery pack is 3.9v and also has spec a of 3000maH. The shake light will put out a AC current after I gut it. Is it possible to slowly charge the battery pack with the small and inconsistent AC currents generated?
  8. MrMaxwell
    May 28, 2011
    26
    Okay. I believe that if I cut off the battery packs original adaptor, and then connect the battery packs power cord to the linked circuit, then it should work. Do you agree?
  9. CDRIVE
    Jul 1, 2008
    2,223
    99
    Did you read these specs from the HF link? You'll be shaking that thing until your wrist falls off!
    • Seven accessory adapters for Samsung, Motorola, Nokia and Sony-Ericsson
    • Retractable USB cable
    • Pack recharges in 3-1/2 hours
    • Charges most cell phones within 2-1/2 hours
    3.9 volts3000 mAh
  10. MrMaxwell
    May 28, 2011
    26
    But will it work? I'm hoping that the current would be able to pass through the pack and charge a mobile device? I know this technology is out.
  11. BillB3857
    Feb 28, 2009
    2,402
    348
    Google is your friend... http://express.howstuffworks.com/autopsy-shaker-flashlight.htm
  12. Adjuster
    Dec 26, 2010
    2,147
    300
    I think that you should able to get some charging effect out of this, but you may need to use a boost voltage converter to increase the output voltage from the generator. I am quite certain though that a full charge would take an impracticably long time.
    The battery pack you mention might need about 18 watt-hours of input to recharge it fully (the exact amount depends on its efficiency), but it would surprise me if you got more than a small fraction of a watt out of that shake generator. A full charge would thus take days of continuous effort, and most likely the user would be suffering from a bad case of RSI before then!
  13. Kermit2
    Feb 5, 2010
    3,847
    963
    If the device outputs a HIGHER voltage than the battery pack then it WILL charge the battery.
    Be sure you have a diode in the charge output line to prevent the battery from discharging through the charger during the period when voltage is lower than the battery voltage.
    Simple pimple. Now you just have to convince someone to shake the thing for several days to get a battery charged.
  14. kubeek
    Sep 20, 2005
    4,687
    805
    I think if you could find a magnet lets say size of a C battery, then you could use some some springs on each side to make the magnet resonate at some reasonable frequency, which could help with efficiency. Of course the bigger size of the magnet will help too.
    ETA: For example a magnet like this: http://www.amazingmagnets.com/show-fractional-r1000f.aspx and a proper coil could make some significant output. Watch out as it is a very powerful magnet and you will have trouble getting it off metal surfaces.
  15. CDRIVE
    Jul 1, 2008
    2,223
    99
    IMO, this is the only 'practical' circuit for a shaker generator. Charging a battery.....???? .... Not so much! ;)
    Edit: BTW, shouldn't there be a limiting resistor? A large cap can pump out quite a bit of current.
  16. MrMaxwell
    May 28, 2011
    26
    I've decided to make the flashlight big enough to accommodate four of the same size batteries (Ceramic grade 5 though). I now believe that a diode will allow me to charge the pack by cutting off the adaptor of the battery pack. Also, I'm attempting to make the generator with 2awg magnetic wire.
  17. kubeek
    Sep 20, 2005
    4,687
    805
    Ideally you should have large enough voltage to allow simple rectification and conversion to feed the battery.
  18. MrMaxwell
    May 28, 2011
    26
    Are you referring to my last post with this statement?
  19. Kingsparks
    Member
    May 17, 2011
    118
    5
    How many turns do you plan for the generator?
  20. MrMaxwell
    May 28, 2011
    26
    1200 or more. I'm ordering 500ft of 22awm magnetic wire.
