Is this PIC (PIC12F509-I/SM) suitable for modulated IR generation?
Discussion in 'Embedded Systems and Microcontrollers' started by AchMED, Nov 6, 2008.
  1. AchMED
    Thread Starter Active Member
    Aug 5, 2008
    41
    I’ve built a transistor crystal osc using the INFINEON BFR92P at 1.8432MHz. I selected this frequency because I want a pulse width of 2.6uS at 38 kHz, Modulated at 1.25 kHz.
    I was going to use logic maybe the 74293 and some gates, but if it all can be done with one 0.60 cent 8 pin PIC I would prefer to use that.
    I found this site which already has the code.I know cheater:)
    Code ( (Unknown Language)):
    1.     http://www.rentron.com/Infrared_Communication.htm
    2.
    If it isn’t already obvious I’m new to PIC’s so I have a question regarding using an external osc.
    Does the PIC prefer sine or TTL input when using an external osc?
    I have this DV164121 - Development Tools - PICkit 2 Debug
    1.     [URL]http://canada.newark.com/16M6058/semiconductors-tools-accessories/product.us0?sku=microchip-dv164121&_requestid=3676[/URL]
    2.
    Do I need anything else to program the PIC12F509-I/SM with the code at the site above?
    Would a different oscillator frequency be better?
    The site above suggests a PIC12C508 which is twice as much as the PIC12F509-I/SM making it not really cost effective. I can’t see any difference between the two after skimming through the 100 plus page datasheet.
    THANKS
