Is this material even existed?
Discussion in 'General Electronics Chat' started by probecard, Aug 18, 2011.
  1. probecard
    Aug 18, 2011
    I've been reading from an article lately saying that the new material of pcb is invented. It has the flexibility of the fpc, and also can take heat as aluminum board. I was told by pcbfinpo, and they claim it is on its testing stage. Does anyone know about it? www.pcbfinpo.com
  2. #12
    Nov 30, 2010
    16,665
    7,313
    No. Not even Finpo. It's still in the testing stage.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Kapton® polyimide insulation was banned from use in US Navy/Marine aircraft, as use of the material led to numerous difficult-to-explain in-flight emergencies, and numerous destroyed aircraft. Kapton is a wonderful insulator, but even small scratches can cause the material to split; and when that happens, the material tends to return to the form it was made in. Kapton tape will tend to straighten out; if it is wrapped around a wire, it will tend to unwrap. Once the material gets weakened, it's also prone to flash-overs and carbon tracking.
