Is this is a bad article writing ?
Discussion in 'Off-Topic' started by sagar474, Nov 11, 2012.
  1. sagar474
    Jul 22, 2010
    16
    This is my blog article that I have recently posted.
    please tell me your suggestion.
    My First Solar Projection
  2. spinnaker
    Oct 29, 2009
    5,085
    1,183
    You are missing capital letters at the start of some of your sentences.
    Actually I am not sure if your trip to the shore is relevant. It depends on what you want to convey to the reader. If you want the reader to learn how you did the project that that information is irrelevant. You might want to mention what kind of line of sight you need to the sun but that is all you need.
    If it is an article just for general interest then mentioning of the shore trip is not a problem.
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    Reading it, it becomes obvious that English is not your first language.
    If you would like to fix it up for publication and at the same time improve your English you should ask someone to edit it.
  4. maxpower097
    Feb 20, 2009
    795
    388
    also use 2 sheets. Put a pin hole in the top sheet then it will project eclipses on the bottom sheet. They taught us that in school for eclipses.
  5. maxpower097
    Feb 20, 2009
    795
    388
    Also if your just learning englist try using MS word, it actually fixes grammer mistakes and will add that period so you can see it automatically make a new sentence a capital, add a comma or period.It will also highlight where it thinks there are mistakes with nouns, verbs, etc.
