Can I manually solder this crystal with normal temperature controlled IRON wih SMD tip?
http://www.digikey.com/product-detail/en/AA-16.000MALE-T/887-1660-2-ND/3454676
I used to do it that way until I discovered paste solder, which makes it much easier.I am with ErnieM, that's pretty much how I would do it.
I have spooled solder and my iron on my bench. Using paste takes a trip to the fridge, but then I'll turn on the hot air side of my solder station.I used to do it that way until I discovered paste solder, which makes it much easier.
