Is this considered a common-base configuration?
hp1729
Joined Nov 23, 2015
2,304
In basic circuit descriptions the common-base design have the base connected to ground. If we return the base to VCC through a resistor is this still considered a common base circuit? I can't remember ever seeing it demonstrated. This is the basic input design for a TTL gate. Or is it just the equivalent of the diode circuit?
34,469
Q2 does perform the basic function of the two diodes so it's not really a common-base design, except that the transistor does conduct as a transistor when the input goes low to discharge any capacitance at the collector of Q2 and the base junction of Q1.
That's why the TTL circuits are faster then the DTL circuits they replaced.
So perhaps you could say its a mixed use. ;)
hp1729
Joined Nov 23, 2015
2,304
When the input goes low Q2 doesn't really act as a transistor. It just conducts up through the resistor. When the input goes high that diode shuts off and the other diode conducts from base of Q1, through the diode and up through the same resistor. Or is my understanding wrong?
34,469
It is incorrect.
When the input goes low, the base emitter is now forward biased due to the base resistor, allowing normal collector-emitter transistor action.
Since, at the instant this happens, the collector is at a higher voltage than the emitter, due to the charge on the stray capacitance at the collector node, the transistor action will discharge this capacitance until the collector and emitter voltages are essentially the same.
Of course, when the input goes back high, the base emitter current stops and it no longer acts as a transistor, with the base current now going through the base-collector junction.
This is shown in the below for a simulated TTL input.
I used a high value of stray capacitance to better show the action.
Note the fast fall-time at the capacitor due to the transistor action causing the high spike of current through the collector, but the slower risetime since then the capacitor charge current is being provided by the base resistor.
KL7AJ
Joined Nov 4, 2008
2,229
That's really a lamely stated question. But yes, the first transistor is common base. I'd give an F to the question writer though. :)
RichardO
Joined May 4, 2013
2,270
Notice that if the input is pulled high enough, the transistor now has the emitter more positive than the collector. The transistor still has gain in this reversed condition but it is much lower than the normal gain.
hp1729
Joined Nov 23, 2015
2,304
I'll take the F, of course. If I thought I understood the topic thoroughly I wouldn't pose the question.
34,469
Here's a interesting result with a more typical 3V TTL logic level input swing.
The output actually goes about 0.1V higher than the input due to charging from the base resistor.
hp1729
Joined Nov 23, 2015
2,304
I just don't see the action of a transistor with the emitter and collector current being nearly equal. Either the emitter is conducting (low in) with low collector current, or the collector is conducting (high in) with low emitter current. So Q2 never actually acts as a transistor.
RichardO
Joined May 4, 2013
2,270
Good point. The transistor would only be backwards if the emitter voltage is above the power supply. This could be caused by ringing on the input, I suppose.
34,469
As I discussed and showed in my simulation, it does momentarily act as a transistor when discharging the stray capacitance at the collector when the input goes low.
It's precisely this transistor actions that made TTL faster than the DTL circuits it replaced.
