is this cap good
Discussion in 'General Electronics Chat' started by insomnia, May 2, 2010.
  1. insomnia
    Jan 27, 2010
    15
    the value on the cap is as follows all readings were done out of the circuit
    2200uf 16v esr reading 1929uf 0.03 esr
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    With what instrument did you measure the values?
    Electrolitic capacitors can have tolerances upto 20 %.
    This means the 2200 μF can measure any value between 1760 and 2640 μF.
    Greetings,
    Bertus
  3. insomnia
    Jan 27, 2010
    15
    hi and thanks for reply i meassured it with the peak esr meter
  4. retched
    Dec 5, 2009
    5,201
    313
    1929 uF is within the range of acceptable for most standard caps.
    Depending on your circuit, it may or may not do.
    If you have a circuit that requires very accurate capacitance, it may not cut it.
    Is there any visual signs of damage? Odd stains, ruptures, or dents?
  5. alim
    Dec 27, 2005
    113
    Hi Do you have a chart of resistance readings vs capacitance values. My DICK SMITH ESR shows 1000uf at .09 ohms and 4700 uf at 0.20 ohms , it does not vave a value for 2200uf, but by extrapolation I would say a .03 ohms reading is good.
  6. insomnia
    Jan 27, 2010
    15
    that was with peak esr meter i would think its also good just checking im reading it correct does anyone know were to get a chart for these readings
