Is this boolean statement reduced correctly?
Discussion in 'Homework Help' started by randb, Jan 1, 2013.
  1. randb
    Dec 29, 2012
    16
    original problem = x'+y'+xyz'
    my steps
    y'+xyz' reduces to y'+xz'
    and x'+xz' reduces to x'+z'
    therefore my answer is x'+y'+z' ?
    randb
  2. WBahn
    Mar 31, 2012
    18,094
    4,920
    Well, ask if your answer seems equivalent in light of the earlier problem you posted. In order for the answer to depend on the term xyz', the first two terms have to be False, meaning that both x and y have to be True. But if x and y are both True, then the term xyz' is equivalent to z'. So, yes, it makes sense that your answer is correct.
    The steps you took to arrive at your answer are correct, as well.
    randb likes this.
  3. randb
    Dec 29, 2012
    16
    WBahn
    Thanks again. Your explanations have been very helpful.
    randb
