is this 115 or 220?
Discussion in 'The Projects Forum' started by cgeod, Jun 1, 2016.
  1. cgeod
    Jun 1, 2016
    Not sure if this is the correct forum - if not - I apologize. If so, is there anyway you can figure out if the voltage generated by the switch in the attachment is 115 or 220 volts? Many thanks - chris
  2. wayneh
    Sep 9, 2010
    12,394
    3,246
    That's a circuit breaker, actually two ganged together, and there's not enough shown to tell what the voltage is.
  3. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Looks to me like the label shows the breaker is a Siemens Q220 type rated for 240VAC.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    If you're in the U.S. that is a 240 volt pair.
    cgeod and GopherT like this.
  5. crutschow
    Mar 14, 2008
    13,508
    3,385
    Again illustrating why posting your location should be as op out, not an op in. :rolleyes:
    Brevor, #12 and shortbus like this.
  6. cgeod
    Jun 1, 2016
    That did the trick - thank you much.
    chris
  7. cgeod
    Jun 1, 2016
    I've updated my location . thank you.
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Two AC power phases, one per breaker, going to a load that requires both or none be present. 120 Vac RMS per line with respect to Neutral, 180 degrees apart in phase, appears as a single 240 Vac power source to the load.
    ak
  9. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    US domestic supply is 240v SINGLE phase with 120v C.T.
    The picture shows a single phase double breaker.
    Max.
