Is There Way To Check Infra Red Led In Remote Tv Is Good Or Broken By Analog Meter
Discussion in 'General Electronics Chat' started by electronics_field, Oct 19, 2006.
  1. electronics_field
    Oct 19, 2006
    And The Infra Red Led Tested Take Of From Remote Or Inside
      File size:
      2.2 KB
      80
  2. EEMajor
    Aug 9, 2006
    67
    Hi.
    There are a few ways you can check this. The easiest method is to go to radio shack and by a little card that reacts to IR light, made for this reason. They are a couple of bucks. You point the remote at this card and push a button, if the card "glows" it works.
    Second, you can check to see if voltage is being applied to the LED with a meter. This is not a sure check, as the LED may be bad but still getting voltage.
    Third, you could use your DIODE check if you have on on your meter for a much more reliable result.
    Fourth, if you have no DIODE function, hook your meter in series with your LED and see if it is drawing any current. Again, less of a sure method then number 3 or number 1.
    In addition, if you are ambitious, you could build a really simple circuit with a phototransistor sensitive in the IR range, plus a regular LED. When the phototransistor detects the IR signal, it will light up the LED. If no signal is detected, no LED is light up.
  3. electronics_field
    Oct 19, 2006
    My Question Is Is There Any Procedure To Check Infra By Analog Meter
    Not Whole Remote
    Only Infra Led
  4. saint_jay77
    Member
    Oct 19, 2006
    26
    The easiest way to check if ir LED is still working is by taking a digital camera and placing it in front of the LED. If when you apply power to the LED with a nine volt batery with a 400ohms resistor in series you should see bright spots on the camera LCD display. If you do see this you know LED is OK; This is by far the most easiest. you might have to align the camera perpendicular to the LED to see something......
  5. mozikluv
    Jan 22, 2004
    1,437
    hi,
    if you insist on an analog multimeter, then do a diode check procedure.
    moz
  6. JoeJester
    Apr 26, 2005
    3,387
    1,211
    I'm curious as to why measuring the current through the device is an unsure method in your mind. I do realize you would have to take into account of the duty cycle of the pulses which would lower the current "observed" on the meter considerable, if not unreadable. That is the limitations of your meter ... not an unsure method.
    I do agree the IR card or the Diode test function are better methods with a GP DMM.
  7. EEMajor
    Aug 9, 2006
    67
    You are correct. That is essentially my worry with this method, but if he has the ability to power the LED with a steady source (like the 9V mentioned) then its a good method.
  8. electronics_field
    Oct 19, 2006
    thanks sir can you give me procedure how to check i am new in this field
  9. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Some meters have a diode check feature built in.
    http://www.kilowattclassroom.com/Archive/AN0001.pdf
    The other is to use a multimeter on the ohms scale but I have completely forgotten it. : (
    This will only tell you the junction is still something of a junction and most likely good.
  10. kubeek
    Sep 20, 2005
    4,686
    805
    As for the methods, current flowing through IR diode doesn´t make you any sure that the diode emits light, so the best method is number 1, or using IR transistor. The camera trick is also useful, but you have to be sure the camera doesn´t reject IR light - better models usualy have filters to be sensitive only in visible range.
