is there something wrong with this code? This is for PIC16f886 where the project will work depending on the LDR and temperature sensor in the hardware part.
Please, anyone, please help me to look at it.
I would need to confirm that nothing wrong with the code.
Thank you.
Rich (BB code):
#include <pic.h>
__CONFIG(INTIO & WDTDIS & PWRTDIS & MCLRDIS & UNPROTECT & DUNPROTECT & \
BORDIS & IESOEN & FCMDIS & LVPDIS & DEBUGEN);
__CONFIG(BORV21);
#define FOSC 8000000L
#define LDR_THRESHOLD 50
#define MAX_DCYCLE 255
const char SSEG[] = {
0b11000000,
0b11111001,
0b10100100,
0b10110000,
0b10011001,
0b10010010,
0b10000010,
0b11111000,
0b10000000,
0b10010000,
0b11000110,
0b10001110
unsigned char DispDigit[4];
unsigned char DigitCount;
unsigned char TempType;
static void interrupt isr(void)
if(T0IF){
PORTC = DispDigit[DigitCount];
PORTB = ~(1 << DigitCount++);
if(DigitCount >3)
DigitCount = 0;
TMR0 = 156;
T0IF = 0;
#define _delay_us(x) { unsigned char us; \
us = (x)/(12000000/FOSC)|1; \
while(--us != 0) continue; }
void _delay_ms(unsigned int ms)
unsigned char i;
do {
i =4;
do {
_delay_us(164);
}while(--i);
}while(--ms);
void SSEG_putnum(float number)
unsigned char iDigit, iDigit1, iDecimal;
if(number > 99.9) return;
GIE = 0;
iDigit = number;
iDecimal = (number - iDigit) *10;
DispDigit[1] = SSEG[iDecimal];
if(iDigit >= 10) {
iDigit1 = iDigit / 10;
DispDigit[3] = SSEG[iDigit1];
iDigit = iDigit - (iDigit1 *10);
} else {
DispDigit[3] = SSEG[0];
DispDigit[2] = SSEG[iDigit] & 0x7F;
GIE = 1;
void main (void)
unsigned int iValue, iCTemp;
unsigned char ldr_value;
float CentTemp;
OSCCON=0x70;
TRISA = 0xFF;
TRISB = 0x00;
TRISC = 0x00;
ANSEL = 0b00000011;
ANSELH = 0b00000000;
PORTC=0xFF;
PORTB=0xFF;
OPTION = 0b00000101;
TMR0=156;
T0IE = 1;
GIE = 1;
CCP1CON=0b00001100;
CCPR1L=MAX_DCYCLE;
T2CON=0b00000101;
PR2=0x65;
TMR2=0;
PSTRCON=0b00001000;
DigitCount=0;
TempType=0;
DispDigit[0]=SSEG[10];
DispDigit[1]=SSEG[0];
DispDigit[2]=SSEG[0];
DispDigit[3]=SSEG[0];
for(;;){
ADCON0=0b11000001;
ADCON1=0b10110000;
GODONE=1;
while(GODONE) continue;
iValue=ADRESL;
iValue += (ADRESH << 8);
iCTemp = iValue;
_delay_ms(50);
GODONE=1;
iValue=ADRESL;
iCTemp += iValue;
_delay_ms(50);
GODONE=1;
iValue=ADRESL;
iCTemp += iValue;
CentTemp=(iCTemp/3.0)/ 10.24;
ADCON0=0b11000101;
ADCON1=0b00000000;
GODONE=1;
ldr_value = ADRESH;
if (ldr_value > LDR_THRESHOLD)
ldr_value = LDR_THRESHOLD;
CCPR1L=MAX_DCYCLE - (5 * ldr_value);
if (RA4 == 0) {
_delay_ms(1);
if (RA4 == 0) {
TempType=~TempType;
if (TempType) {
CentTemp=((9/5) * CentTemp) + 32;
DispDigit[0]=SSEG[11]; // Fahrenheit Sign
} else {
DispDigit[0]=SSEG[10]; // Centigrade Sign
SSEG_putnum(CentTemp);
_delay_ms(200);
Thank you.
