is there something wrong with AAC?
Discussion in 'Feedback and Suggestions' started by PG1995, Jan 11, 2012.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    I have unsuccessfully tried to start a new thread in General Electronics forum several times in the last few hours. I get this error: http://img834.imageshack.us/img834/9223/aacprob.jpg
    I have checked it on more than one browser. The same problem also happened some days ago but then it resolved on its own. Please let me know if other members are also experiencing the same problem. Thanks.
    Regards
    PG
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Does the problem persist? I managed to create a new thread in the General Electronics Chat right now.
  3. PG1995
    Apr 15, 2011
    753
    5
    Thanks for the reply.
    Yes, it's still there. What do I do?
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I 'll be darned if I know. I 'll report it and see what comes out of it.
    Is it only on General Electronics Chat or in any forum?
  5. PG1995
    Apr 15, 2011
    753
    5
    I think it only happens with General Electronics Char as far as I know. As I mentioned earlier this also happened some days ago but then it got fixed on its own.
    Regards
    PG
    PS: I have tried three different browsers. It isn't working. And worse things is all these forums Off-Topic, Projects, General Electronics Chat aren't working (perhaps, there are more but I have only tested these).
    Now I have tried two different internet connections from two different ISPs.
    Now I'm sure there is some issue with AAC forums.
  6. PG1995
    Apr 15, 2011
    753
    5
    Is this possible for you to start a new thread for me under my username so it appears under my started threads list.
    Title:
    low voltage cutoff circuit
    Content:
    Hi
    I think this circuit is used to cutoff the voltage source to the output if it's the voltage is 6V or lower. Do I have it correct? I googled "6v low voltage cutoff" and found this somewhat similar looking circuit.
    The red LED is for power indication in the circuit and the white LED is for low voltage indication.
    Is that component on the top left a relay?
    What is that IC on the top right? Someone was saying that the circuit uses operational amplifier. But someone said it could be a LM393 dual comparator. What do you think?
    In what kind of applications this circuit can be used? Could you please list some examples of circuits or electronic products which can be damaged by low voltage if they don't use such voltage cutoff circuit.
    Thank you for the help.
    Regards
    PG
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    Done. Let me know if you need anymore threads created.
    When I tried to create the thread with the full message body it would freeze the process. After I entered "blah blah blah" as message body the thread was created.
    PG1995 likes this.
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    It was running kind of slow for me yesterday, but that might have been me. Just a thought.
