Is there flux inside an ideal transformer with a shorted secondary?
Discussion in 'General Electronics Chat' started by nickw1881, Dec 25, 2009.
Thread Status:
Not open for further replies.
  1. nickw1881
    Dec 25, 2009
    31
    I am learning about transformers, but one question that is bothering me, which no book seems to clearly answer, is whether or not there is flux in the core of an ideal transformer with a shorted secondary winding.
    If current in a loop flows to oppose changes in flux, then in an ideal transformer with a shorted secondary, no flux should ever exist in the core, because as soon as flux increases from zero, opposing flux from the secondary winding would cancel it out.
    Non-ideal transformers have at least some flux in their cores, because they have measurable reluctance, or even an air gap, which is why equivalent circuits have a parallel inductor and resistor. Assuming the transformer is well built, this amount of flux should fairly small as long as the transformer is driven at the proper frequency. So here is the question that has been bugging me for years:
    Why does every textbook and core datasheet make it seem like the B-H curve is the be-all end-all of transformer core selection?! Unless the transformer is only lightly loaded there IS NO FLUX to worry about. What am I missing here?
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    Normally, the short circuit test (secondary) for a transformer is done at a much reduced power level to measure copper (I²R) loss because there is no output power or core loss. Does that answer your question?
    Cheers, DPW [ Everyone's knowledge is in-complete...Albert Einstein]
  3. nickw1881
    Dec 25, 2009
    31
    Maybe this is more of a physics question. Can I move threads?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sure, I'll close this one.
Thread Status:
