Is there an integrated circuit for...
Discussion in 'The Projects Forum' started by Mr.Wolf, May 14, 2009.
  1. Mr.Wolf
    May 14, 2009
    Hi all,
    Thank you in for any help provided.
    I am trying to build an interface for the parallel port and I have been looking for a few days now and almost have what i want.
    Now I am looking to condense it.
    As most people know their is 8 "Data" pins in the parallel port, I am want to use four of those to "broad cast" to latching relays via a IC7408 and four to address them
    What i need is to be able to address to more then 4 IC7408's.
    please correct me (if I'm wrong) but with four inputs I can have a possible 16 outputs so as a result 64 (16 outputs* 4 the other data pins) possible latching relays.
    I know i can achieve the 16 outputs using a combination of xor gates and diodes (to avoid cross contamination). However, it would be nice if their was a single chip I could use (I'm guessing their would be 22 pins (4 input + 16 output + 1 Ground + 1 Active)
    Thank you, again in advance for any suggestions.
  2. RiJoRI
    Aug 15, 2007
    536
    26
    At work we use the CD4067 four to sixteen Multiplexer/Demultiplexer.
    --Rich
  3. Mr.Wolf
    May 14, 2009
    Thanks Rich,
    Excellent, looks like what I needed.
    However, upon googling it to try and buy one I came across another product the CD4514BC don't suppose you know the difference? at first look their data sheet appears to be very similar other then the CD4067 accepts a larger range of voltage bellow is a link to the CD4514BC data sheet.
    thanks again.
    http://www.jaycar.com.au/images_uploaded/CD4514BC.PDF
    - Shawn.
