Is there a way to make a NC thermistor work as a NO one?
Discussion in 'The Projects Forum' started by j4e8a16n, Mar 24, 2014.
  1. j4e8a16n
    May 1, 2013
    33
    Normally opened
    Normally closed
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    theremistors vary their resistance with temprature, not act as switches.
    j4e8a16n likes this.
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    Are you referring to surge-limiting type thermisors?
  4. Dodgydave
    Jun 22, 2012
    5,161
    772
    Do you mean Ntc and Ptc ?
  5. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Or is this a N.C. thermal bi-metal sw?
    Max.
  6. j4e8a16n
    May 1, 2013
    33
    See attachment
  7. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    From the data sheet it appears to be bi-metal, if so there is no way to invert it without a external device, relay etc.
    What is the application?
    Max.
  8. j4e8a16n
    May 1, 2013
    33
    To start a 3v motor with a fan when the transistors heatsink reaches 100°C .
  9. inwo
    Nov 7, 2013
    2,435
    315
    Like Max posted.
    Use a relay to invert.
    Or for your small load you could use a transistor between sensor and motor.
    Seems a large device for your purpose. They are generally slow and have a large differential.
  10. j4e8a16n
    May 1, 2013
    33
    I just connected the two poles of the thermistor to the 2 poles of the motor. This creates a bypass when the thermistor is closed.
    When it opens the current run the motor. :eek:)
  11. MrChips
    Oct 2, 2009
    12,648
    3,458
    Buy a NO (normally open) thermal switch.
  12. Alec_t
    Sep 17, 2013
    5,979
    1,138
    So what prevents that bypass short-circuiting the supply?
  13. BillB3857
    Feb 28, 2009
    2,402
    348
    That's great as long as your power supply can accept a full short circuit while the motor is supposed to be off. Also, lets call it what it is.... THERMOSTAT, not thermistor.
  14. j4e8a16n
    May 1, 2013
    33
    What would be a better component?
  15. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    The current will probably open the Bi-metal switch :eek:
    Heck of a way to control a motor on/off.:confused:
    What are you trying to do exactly?
    Max.
  16. j4e8a16n
    May 1, 2013
    33
    I agree EEK!
    When the heatsink is too hot , the fan starts; when it cools down, the fan stops.
  17. j4e8a16n
    May 1, 2013
    33
  18. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Show how you have the circuit wired right now?
    Max.
  19. MrChips
    Oct 2, 2009
    12,648
    3,458
    What you want is a KSD9700 thermal switch which is available as NO (normally open) or NC (normally closed) with temperature set points 25-180°C in steps of 5°C.
    KSD9700 NO 100°C
    http://www.sourcingmap.co.uk/ksd9700-100-bimetal-normal-open-type-temperature-control-switch-pcs-p-121743.html
    KSD9700 NO 60°C
    http://www.frozencpu.com/products/16492/tmp-68/Fully_Automated_KSD9700_Series_Thermal_Switch_-_60_Threshold_On_at_60C_Off_at_40C_.html
    Data Sheet:
    http://www.ic-world.com.cn/pdf/20120724220954.pdf
    Edit: Reading the description from the supplier it is not clear that these are NO (normally open) switches.
  20. j4e8a16n
    May 1, 2013
    33
    What would be the advantage of putting the motor at the emitter?
