is there a way of delaying an led without using a 555 timer
Discussion in 'The Projects Forum' started by james555, Dec 20, 2014.
  1. james555
    Dec 20, 2014
    11
    perhaps a transistor and capacitor combo.. it does not have to be precis just a second or two would do
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What LED current?
    What LED Vf?
    What supply voltage?
    How long an interruption of input power before the next timing cycle?
    Can we use R,C, transistor and diode?
  3. wmodavis
    Oct 23, 2010
    737
    150
    Arduino?
  4. james555
    Dec 20, 2014
    11
    3v (2AA)
    yeah i was thinking a resistor/ cap combo would do
    using a arduino in this basic application would be like using a shot gun to kill a fly.. it would work but im looking for basic.. as basic as can be
  5. wayneh
    Sep 9, 2010
    12,394
    3,246
    It will - just experiment. You'll need a relatively large capacitor. If you don't like the behavior you get, you'll have to use something more elaborate.
  6. wmodavis
    Oct 23, 2010
    737
    150
    Didn't see in your OP anything about looking for 'basic as can be'. Just responded to what you said with a possibility you could consider based on your stated criterion.
  7. #12
    Nov 30, 2010
    16,704
    7,354
    Did your last job involve designing modern cars? :rolleyes:
  8. wmodavis
    Oct 23, 2010
    737
    150
    Nope. Not into plumbing.
  9. #12
    Nov 30, 2010
    16,704
    7,354
    Good. I wouldn't want the water in my tail lights to be regulated by a microprocessor.
  10. tracecom
    Apr 16, 2010
    3,879
    1,396
    Overkill. A PICAXE would do. 28-pin, of course.
    #12 likes this.
  11. donpetru
    Nov 14, 2008
    186
    25
    Modify the following circuit (you have to adapt it to operate at 3V):
  12. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    use a 2n7002, with a 4.7 M Ohm resistor, a small capacitor will do.
    Higher value resistors are difficult to get even though, they exist.
  13. james555
    Dec 20, 2014
    11
    hay man it ok.. i should have specified
    in fact i'll be using a mp board later in my project
  14. LDC3
    Apr 27, 2013
    920
    160
    With only 3V, the BJT would probably work well, but at higher voltages I would think a MOSFET would be better.
  15. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is the brute force way, but it has several problems, the least of which is the huge capacitor required. It also has a "recycle" problem, in that it takes a relatively long time for the timing capacitor to discharge to get ready for a new delay cycle after the switch is opened. Note that this is about the best that can be done with this circuit. If you make R2 smaller to discharge the capacitor faster, then it wastes a lot of power while the switch is closed.
    Here is a better way. This reduces the capacitor size and improves the recycle time
