Is there a voltage regulator?
Discussion in 'The Projects Forum' started by dhosinski, Jan 19, 2009.
  1. dhosinski
    Thread Starter Active Member
    Dec 6, 2007
    40
    Hello, I am currently using two full wave rectifiers for my senior project. One is being used on my current dimming circuit 120v, and the other for a low voltage (12v) 555 timer circuit.
    Is there anything available that I can use instead of using two full wave rectifiers? Maybe a 120VAC (ripple) to 12VDC output?
    If I could find an alternative I could reduce my circuit by a minimum of 4 diodes and a transformer.
    Thank you!
  2. mik3
    Feb 4, 2008
    4,846
    63
    If the 120V is filtered then you can use a switched mode power supply to step it down to 12V.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The best way to get the 12 volts is to use a transformer. A little wall transformer is cheap and, most importantly, safe.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    You can even get them in module form, in the form of a wall wart. Filtered and regulated in a cheap package.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    "Wall warts" are typically rectified, but not regulated nor filtered.
  6. KL7AJ
    Nov 4, 2008
    2,043
    293
    There is an old old old trick for doing this....called the "economy" power supply. Very tricky..wish I'd invented it. You need a transformer with a low voltage tap on the secondary. What you do is you put a full wave bridge across the "main" secondary winding, and put a filter on that. This is your high voltage supply Then you take the tapped winding, which will now have DC on it relative to ground, but it's still got a lot of ripple. You put a filter cap across that and, voila...low voltage dc! Two voltages with one rectifier.
    Cool!
    eric
    Eric
  7. dhosinski
    Dec 6, 2007
    40
    Thank you for your suggestions everyone. My current design consists of a low voltage circuit (timer) and a HV current mode amplifier that will drive LEDS.
    The low voltage circuit currently has a 120/12v transformer that is then rectiifed to a 12v ripple and finally input to a 12VDC voltage regulator. The regulator output obviously feeds the timer circuit.
    Maybe the "Buck Mode" powersupply is the best idea? Are there any designs online that I can look at?
    Darrin
  8. mik3
    Feb 4, 2008
    4,846
    63
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Hmmm, we must be using different sources then, cause I have quite a few. I also have wall warts that are AC out, so you have to read the specs on them. For those with DC out filtered is the minimum spec.
  10. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    There is no need for a full wave bridge except to reduce ripple. Loose the diodes, increase the caps. If the cap. gets too big go to full wave.
    russ_hensel
  11. dhosinski
    Dec 6, 2007
    40
    How can I rectify 120VAC to 12VDC without using a full wave rectifier? If I use a half wave it's going to affect the operation of the timer circuit isn't it?
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The easy way is to use a transformer that has a center-tapped secondary, like 12v-0v-12v. You ground the center tap, and use two diodes for the ends of the transformer, anodes connected to the windings, cathodes connected together.
  13. dhosinski
    Dec 6, 2007
    40
    I appreciate the suggestion but I am already using a 120VAC/12VAC transformer. From there I am using a fullwave rectifier and the output is going to a 12VDC regulator. I was trying to see if there was a possibility of eliminating the transformer and second fullwave rectifier, but it doesn't seem to be possible.
  14. mik3
    Feb 4, 2008
    4,846
    63
    Do you rectify the 120V AC directly and then smooth it with a capacitor filter or just rectify it?
    I though something 'bad' which may work!!
  15. italo
    Nov 20, 2005
    205
    If you are happy with the 12v then the leds can be driven directly from AC how use a triac photoisolator and a diode in series like 1n4006 to cut the saturation current during [-] swing.
  16. dhosinski
    Dec 6, 2007
    40
    I have two circuits. One circuit (120VAC) essentially uses a switch mode puwer supply as the driver for the LED's, the other circuit is just a 12V circuit that is used for a 555 timer circuit. I am using a full wave rectifier without a capacitor. The timer circuit works I've tested it. I'm just trying to find a way to eliminate the transformer and second rectifier if possible.
    I was thinking of another SMPS circuit?
  17. dhosinski
    Dec 6, 2007
    40
    It's my Senior Project and the circuit is already designed. I am just trying to reduce components where possible.... If I can reduce 120VAC to 12VDC without using a transformer and second full wave rectifier I can reduce some of the cost of my circuit.
  18. mik3
    Feb 4, 2008
    4,846
    63
    How many amps does the timer draws? What does it drives?
  19. dhosinski
    Dec 6, 2007
    40
    The timing circuit solely consists of a regulator (12v) and the 555 timer setup to output a 1kHz signal. That will be used as an input to an "opto-isolator" for the current mode controller.
  20. mik3
    Feb 4, 2008
    4,846
    63
    I won't tell you the idea because it is not safe at all. Better to use a small 6VA transformer and a 1 Amps bridge rectifier to do the job rather get killed.
