Is there a simple way to indicate that contacts are open?
Discussion in 'General Electronics Chat' started by Wobbly, Mar 26, 2014.
  1. Wobbly
    Mar 26, 2014
    Using a neon lamp and resistor across 120 volt contacts with a load resistor in series, the neon will light when the contacts open.
    What is the maximum resistance of the load resistor?
    Please provide help calculating.
    Is there any other discrete device besides a resistor which could be used in series with the contacts and still light the neon when the contacts open?
    No relays allowed!
    No this is not homework.
    It's just a problem I was thinking about going to work yesterday.
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
  3. Wobbly
    Mar 26, 2014
    In my case the loose wire is often in front or the keyboard.
  4. MrChips
    Oct 2, 2009
    12,625
    3,451
    It's relative. Are you behind the wheel or in front of the wheel.
