Is there a resistor available for 330v supply?
Discussion in 'General Electronics Chat' started by victorment, Mar 11, 2011.
Thread Status:
Not open for further replies.
  1. victorment
    Jul 4, 2010
    52
    Is there a resistor for a 330v DC supply?
  2. mkbutan
    Sep 30, 2008
    270
    16
    for what u want to limit the current or to drop the voltage
    yes its available for both
    search the google
  3. victorment
    Jul 4, 2010
    52
    I would like to build a transformerless power supply. here is my circuit. please tell me if it is correct.
  4. S_lannan
    Jun 20, 2007
    247
    Don't build that, you'll probably electrocute yourself.
    This type of power supply is not safe.
    I cannot see any schematics posted either.
  5. victorment
    Jul 4, 2010
    52
  6. S_lannan
    Jun 20, 2007
    247
    Well to put it short every node in that circuit past the bridge rectifier will be at full mains potential... Including what you might think is 'ground'.
  7. victorment
    Jul 4, 2010
    52
    is this right? having a 30v dc output on the load resistor when It simulate it?
  8. victorment
    Jul 4, 2010
    52
    can I use 5 watts resistor on this?
  9. mcgyvr
    Oct 15, 2009
    4,787
    973
    This thread will/should be locked. A transformerless supply is not safe for an amateur and thus should not be discussed here.
  10. victorment
    Jul 4, 2010
    52
    Its our project for my school
  11. mkbutan
    Sep 30, 2008
    270
    16
    are you trying to make AC/DC converter?
    normally in these cases cant depend on the capacitors (it blow's off)
    even there will be so much of heat energy will be produce your ckt. will not last for long.
    have you calculated the resistor valves 110Ω before sketch mate
    :rolleyes:
    Mr.MCGYVR is right
    victorment likes this.
  12. mcgyvr
    Oct 15, 2009
    4,787
    973
    Even more of a reason to NOT use a transformerless supply. And your teacher "should" know better than to allow this as a project.
  13. victorment
    Jul 4, 2010
    52
    its our project a transformerless power supply with 24v output and 2 amps. can someone help me.
  14. mcgyvr
    Oct 15, 2009
    4,787
    973
    If your teacher truly allowed this project then you should be talking to him/her. Your teacher should be held 100% liable in this case.
  15. victorment
    Jul 4, 2010
    52
    but the teacher gave us this project. I can't do anything about it.
  16. Papabravo
    Feb 24, 2006
    10,338
    1,850
    It does not matter what it is for. Stop before you hurt yourself or one of your students. No responsible member of the forum will help you in any way. Done, period, full stop.
  17. mkbutan
    Sep 30, 2008
    270
    16
    SORRY SORRY SORRY cant help
    you are not mature enough to handle this project tell your teacher to change the project
    Accidents are never Invited but they Occur
  18. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You MUST use a transformer of some type to isolate the output from mains power.
    There is no other way to make it safe.
    Transformers are remarkably inexpensive compared to a funeral.
    Please do not attempt to build a transformer-less mains-powered supply.
  19. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    All of the above warnings are correct and honestly meant. That circuit is deadly.
    mkbutan and victorment like this.
Thread Status:
