Is there a practical way to remove multi pin DIP ICs ?
Discussion in 'General Electronics Chat' started by LETITROLL, Jun 14, 2014.
  1. LETITROLL
    Oct 9, 2013
    218
    Hello dear members .
    Recently i came across many DIP ICs that needs to be swapped, i have successfully removed some 8 pin ones though , but its a pain to remove the ones with 14 pins and above without damaging some solder holes witch makes the repair more time consuming .
    Am sure me and other members will take benefit of this , please share your methods and techniques .
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    What I usually do, presuming you do not want to keep the old one!
    Is to clip all leads and use a solder sucker to remove individual pins.
    I always fit a socket for future events, if possible.
    Max.
    LETITROLL and absf like this.
  3. inwo
    Nov 7, 2013
    2,435
    315
    Like Max says. +1
    I also have a dip solder tip that heats all pins at once.
    Re soldering all solder joins before removal is a big help.
    The quick and dirty way, for non critical circuits, is to not remove them.
    Clip the old leads long.
    Form them to hold pressure on socket pins.
    Solder socket leads to stubs.
    I know it sounds redneck, but it limits stress on pads and traces.
  4. GopherT
    Nov 23, 2012
    6,327
    4,063
    Use solder wick to remove most of the solder.
    If it cannot be lifted off of the board after solder wick, Have a friend grab the IC with a pair of pliers and then hit the bottom side with a hot air gun. Try to shield other areas with foil to avoid blowing off any SMDs on the copper dose.
  5. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    with a desoldering pump you can even remove DIP40 ICs.
    Epoxy PCBs can be hard to desolder however, even if you get it out in the end, the PCB will become damaged.
    When you extracted all the solder from a single side PCB, simply move a screwdriver under the IC and lever it out.
  6. mcgyvr
    Oct 15, 2009
    4,792
    976
    solder sucker
    or
    dip tweezer tips
    or
    a dip in a solder pot (kapton tape can be used to cover other areas you don't want to disturb)
  7. #12
    Nov 30, 2010
    16,705
    7,355
    In 1973 I worked at a factory where the re-work person had a full blown, foot pedal operated, vacuum pump powered, solder sucker. She could change parts so well that you couldn't tell she had been there.
    Seriously. The red dot that was on the bad part was missing and I could never tell which part I had sent that machine to get replaced.
    So, it can be done. Just, how much are you willing to spend to get factory original quality?
    absf likes this.
  8. loosewire
    Apr 25, 2008
    1,584
    435
    In some applications they are using flat grille cooker on low heat ,it heats all the pins
    evenly to assist in removal.
  9. absf
    Dec 29, 2010
    1,493
    374
    For small and cheap TTL chips I'd use methods already outlined by Max and inwo. But for bigger chips (>= 24pins) I would use method used by GopherT.
    But I learned one thing here using GopherT's method. I didn't remove the excess solder from the holes and just directly blowing hot air onto the chip to be removed at the bottom. This worked but after removing a few chips like that, the whole PCB appeared to become bent and couldn't lay flat on the table.:D:confused:
    I also have a heavy portable vice for doing this job. I used my left holding the chip extractor and my right with the hot air blower. And kept the blower moving from side to side to keep the temperature even.
    Allen
  10. inwo
    Nov 7, 2013
    2,435
    315
    The piggy back socket method is great for non-servicable potted boards. Of which I run into often!:eek:
    You can even leave the old chip in place. A thin cut with cut-off wheel down each side separates the pins.
    Try it you'll like it.
    Who is going to know?:D
  11. LETITROLL
    Oct 9, 2013
    218
    Thanks for the comments .
    I was looking actually for a way to heat all pins at once , and pull the IC from underneath , This way i can get a clean lift .
    Guess i have to invest in some professional tools sooner or later .
  12. LETITROLL
    Oct 9, 2013
    218
    The solder pot and tweezers seems to be more practical .
    Thanks ;)
  13. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I have a trough shaped bit for the iron I have that covers all pins, it works so-so, I usually resort to the clipping pins, as it is rare that I want to save the old one.
    Max.
  14. JoeJester
    Apr 26, 2005
    3,403
    1,227
    look up solder extractor. The run from simple bulbs to thousands of dollars Pace rework stations.
    I used solder wick and then an IC puller. I also used powered desoldering stations.
  15. inwo
    Nov 7, 2013
    2,435
    315
    +1 on the so-so;)
  16. LETITROLL
    Oct 9, 2013
    218
    Just regarding that solder tip , is it possible to make one , not just for DIPs but any other unusual formats .
    Can i make some tips using copper metal ?? or do they make special metal for that ?
  17. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    The ones I have are tin plated copper.
    Max.
  18. #12
    Nov 30, 2010
    16,705
    7,355
    Copper dissolves in lead solder so quickly that I wouldn't waste time making a tip that won't last more than maybe 20 or 30 uses. Look for something retail with proper outer coating.
    LETITROLL likes this.
  19. ScottWang
    Aug 23, 2012
    4,933
    777
    You may need like this and this -- the iron head T-tip.
  20. LETITROLL
    Oct 9, 2013
    218
    Yeah this will work so-so :D
