Is there a lead set with 8mm diameter plugs?
Discussion in 'General Electronics Chat' started by richard3194, Jan 16, 2016.
  1. richard3194
    Oct 18, 2011
    65
    Hi. Maplin Electronics here in UK make a PSU type N93CX. The OUTPUT sockets look like they take shrouded banana-type plugs. Now, I know you can by a set of meter test leads with 4mm plugs that are shrouded. Okay, but a response on Maplin Questions say the OUTPUT sockets are 8mm diameter. So, do 8mm shrouded plugs exist? Thanks.
    EDIT: Messing about with plugs, and my N93CX I've just learned that the sockets on N93CX are actually 4mm diameter. An answer on Maplin Questions gave me a bum steer! So, to confirm: The OUTPUT sockets on N93CX are 4mm diameter. Of course, the shroud is larger.
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
