Is there a dimmable electronic transformer below 60W
Discussion in 'General Electronics Chat' started by gardenyu, Dec 15, 2009.
  1. gardenyu
    Aug 11, 2009
    7
    I try to use a dimmable electronic transformer (for halogen lights) to power my LED supply, which is like 10-20W, but the minimum I found is 60W, which is slightly too big for my application. A 20-30W one is just enough for me.
    Any comment?
  2. rhythmtech
    Jan 7, 2009
    7
    You may want to post a link to a datasheet or some more info on the transformer. I am not sure how having a transformer rated higher than your load is bad. Seems like you would want to do that in the first place, but then again I don't know exactly what kind of transformer you are looking at.
  3. gardenyu
    Aug 11, 2009
    7
  4. Duane P Wetick
    Apr 23, 2009
    408
    19
    Normal AC phase control lamp dimmers don't work very well with the new LED lamps, I've got one in ckt. now and it has just 2 levels, dim and bright with a lot of hysteresis between the two levels. Maybe there are LED lamp dimmers available, but the old style incandescent AC phase control units are only marginal at best. Time for a new design effort...anyone?
    Cheers, DPW [ Always remember that you are not going to live forever.]
  5. gardenyu
    Aug 11, 2009
    7
    well, a lot of people have been working on using the normal forward phase TRIAC dimmer with LED lighting, such as ST, National, NXP and multiple patents.
    I made one that dims pretty good (down to 1%) from several phase dimmers, so this is not a problem actually.
  6. Duane P Wetick
    Apr 23, 2009
    408
    19
    Post the circuit, please. The question is: Is there a 20-30W LED lamp dimmer? The one he is using is 12 VAC @ 25 KHz. (pwm?) or some other variable power device?
    Regards, DPW
  7. gardenyu
    Aug 11, 2009
    7
    it's not a circuit question.
    All electronic transformers perform the same, they take 120 or 240 input and provides 12V or 24V at high frequency.
    I'm just looking for a smaller one since I don't require high wattage.
  8. rjenkins
    Nov 6, 2005
    1,015
    69
    Different makes seem to have different minimum load ratings.
    The lowest I've seen to far is a 60W with a minimum load of 20W.
    I think as they are designed for halogen lamps, the makers don't see a need for lower ratings.
    As LED systems become more popular, hopefully they will start to be produced.
