How can there be a current that is "large enough" if the current is being blocked?Hi,
Is there an electrical component that stops a small current from passing through, but if the current is large enough, is allowed to pass through without destroying the component?
Not a simple component, but a circuit. You would need to get specific about how much current you were talking about.Hi,
The question revolves around "how much current are we talking about?"There is a semiconductor device called a diac that does this.
https://en.wikipedia.org/wiki/DIAC
https://www.digikey.com/products/en?FV=fff40015,fff80040&k=diac
also on Farnell in the UK
You may also want to look at MOV or TVS.
These people are not engineers. It is difficult to respond on the same level they are. Thus the comment "if you gave to ask the question would you understand the answer?"Still no clarification from the OP.
I sometimes have the feeling that some thread starters throw poorly worded questions with a lack of information at us just to watch us flounder, trying to guess at at the correct answer.
Are you, perchance, conflating current with other electrical quantities? -- 'Negative resistance' devices (e.g. thyristors, varistors, 'transient absorbers', Zener diodes, tunnel diodes, UJTs, gas discharge tubes, etc), for instance, might be said to 'block' current flow below certain 'voltage' levels -- Unfortunately the laity (including, IMO, most egregiously, entertainment) have fallen into the 'habit' of referring to all aspects of electrical energy as 'current' sans regard to sense, sanity or anything like reason!Hi,
Perhaps not - but they are students (formally or otherwise) and, more to the point, participants whom might reasonably be expected to exhibit a modicum of courtesy - via, for instance, following up their questions!These people are not engineers.
Ditto! -- IMO pride comes way too high by virtue of its incompatibility with education!At least I admit my ignorance on some subjects.
by Aaron Carman
by Duane Benson
by Aaron Carman
