Is there a compiler for Visual C#
Discussion in 'Programmer's Corner' started by jfeeney, Jul 15, 2008.
  1. jfeeney
    Jul 14, 2008
    14
    In a previous question I asked if a microcontroller supported Visual C#. (Title - Can I program in Visual C# ) However, I think I asked the wrong question. What I really wanted to know if there was a brand of microcontroller who's compiler supported programming using Visual C#.
    So program in Visual C#, then compile the program to run on a simple microcontroller.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ahh, I think you're getting confused here.
    C# and C++ are supersets of the C language. Basically, if you know C++ or C#, you'll know C, but you'll have to forget some of it ;)
    Visual C# was designed with the idea of writing GUI applications for a Microsoft GUI environment. Microcontrollers don't run Windows OS, nor do they need to.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  4. nanovate
    Distinguished Member
    May 7, 2007
    665
    C# is more like JAVA when you are thinking of how it compiles and runs. It requires the .NET framework to run in other words need Windows. As I mentioned in your other thread
    There is also a .NET compact framework that is designed for WIN CE which you may be able to use C# on.
