Is the (HES) 660-12V PRE-LOAD Multi-Purpose lock polarity sensitive?
mackeymartin
Joined Dec 31, 2011
7
I am wiring a 12v dc powered (HES) 660-12V PRE-LOAD Multi-Purpose Lock
and I can't tell which wire was positive and which was ground. When I try both wiring options it seems the lock operates the same. How do I find out whether it will fry if I wire it wrong or is it polarity sensitive?
mackeymartin
Joined Dec 31, 2011
7
I see that it has a red and a black wire, but what I am trying to figure out is if the correct polarity is necessary since I found that it operates when I wire it correctly as well as backwards. I had to extend the wires and connected 2 of the same color wires to the lock, so at the end I cannot tell which one is which. Thats why I need the help.
praondevou
Joined Jul 9, 2011
2,942
If inverting the power supply will do any damage in the long run you would only know if you open the lock and have a look at the circuit.
Since you already inverted it and it still works it's probably ok. It depends on the component that is used to switch on/off the power elctromagnet.
