Hi, Ive replaced a ribbon cable to a heating element with a thermistor. The cable was damaged but everything worked before I soldered in the new cable. The cable does a lot of moving so I thought it would be a good idea to put all purpose silicon where the cable goes into the board so it doesnt bend at the board where it might break off. I now get an error code for temp sensor short circuit though and a temp reading of 120degC when it should be about 25. Could there be current leak because of the silicon?
