Is photography gels glass works in night?
Discussion in 'General Science' started by engr.sajidzaman, Aug 7, 2011.
  1. engr.sajidzaman
    May 9, 2010
    8
  2. Markd77
    Sep 7, 2009
    2,803
    594
    The goggles just block some colours, they won't let you see infrared. At night you will just see blackness.
  3. engr.sajidzaman
    May 9, 2010
    8
  4. Markd77
    Sep 7, 2009
    2,803
    594
    "Pure hoax"
    You can't see IR, no filter will change that.
    <ed>Digital cameras / camcorders can see infrared but there is no need for the gels</ed>
  5. Kermit2
    Feb 5, 2010
    3,852
    967
    The human eye only sees red to dark blue.
    If the infrared could excite a substance to emit light in the red to dark blue spectrum then your eye could see 'infrared'. But only if it is first changed to a freq. in the red to dark blue range. A filter will not do this. A filter will remove a freq from the spectrum passing through, but nothing else. You need a substance which will absorb infrared and 're-radiate' at a visible wavelength. Something similar to the phosphors inside fluorescent light bulbs. They absorb UV light created by electrically excited mercury ions and re-radiate visible wavelengths.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have seen magic on YouTube, but yet I still don't believe in magic. Do you believe in magic?
    Night vision does exist in several forms, but not like this (as has been stated). A simple CCD camera (digital cameras or camcorders) see deeper into the infrared than humans. Simple light sources, such as IR LEDs, will illuminate the scene and you won't see a thing. Far as I know, all night vision is done electronically.
